Old 07-20-2025, 02:02 AM   #1
997_986
Not necessarily. If you have a vice that can be extended long enough, you can also do this with a ring turned to 73.3 mm outside diameter (inner diameter depends on your mount, normally 50mm+) and a sufficiently large counter. But a press is more elegant.
997_986 is offline   Reply With Quote
