Old 07-12-2025, 09:39 PM   #1
pilot4fn
Check if all spark plugs are tight (to torque spec).
If one comes a bit loose, the pressure leaks out just a bit and makes thsi kind of noise that changes by rpm - ususlly shows up only as the engine is hot / normal operating temperature.
I had same in mys Boxster few years ago and torqued all plugs - one was just a bit loose -> chirp noice went away.
If you check the plugs, make sure to re-connect the coil wires real well to the point that you can feel the slight 'click' as the wire connector is all the way home (otherwise there will be misfires).
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
