Old 07-01-2025, 06:51 PM   #10
maxbottomtime
Originally Posted by BoxsterInTheSun View Post
Thanks so much for the help! Mine is the passenger side ( on a US left hand drive car ) so I assume I'm looking for a RIGHT door latch?
Looks like part number 3B1837016P for my 2002 base 986. I honestly have no idea if this car has the 535 alarm option...
I'm also hoping to use either a cheaper aftermarket solution, or get a used ebay part, the $600 original part isn't going to work for my wallet. I found this one on Ebay that looks like it is the right one?
It seems like the super cheap VW part likely won't work for my model?
Thanks again everyone for all the help, this forum is amazing.
The part depends on if you have the alarm or not. The option code is on the underside of the frunk, so start there.
3B1837016P is the passenger if you have the alarm option, 8N1837015A for driver.
Originally Posted by alexc0814 View Post
This is the exact part that fixed my right side passenger door latch issue.
https://www.amazon.com/dp/B08JMWB8TG?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_1
My alarm box says M535 and I have no errors despite the description saying it isn't compatible. Give it a shot and return it if it doesn't work. Easy to swap out the latch once you do it once anyway.
Your link doesn't load. You need 3B1837016P if you have the 535 option.
maxbottomtime is offline   Reply With Quote
