Old 06-11-2025, 05:28 PM   #2
jaimster
Originally Posted by Danimal View Post
When you manually lock the car, do the instrument cluster and the interior lights turn off? If so, I have the same problem. However my car will generally lock after it sits for a day or so. After 30ish minutes of drive it’s back to not working. I replaced the passenger lock assembly, but no luck.
wow
so somewhere i had read if you turn the key five time to the right (locking side ) then back to center/mid sometimes it will reset the system it WORKED .. IS WORKING
have you try that ??if NOT give it a shot - as far replacing the passenger side lock I had also read about that not convince that would be the fix .. also disconnecting the battery for a few minutes
if you have Durametrics or can get your local fellow member that has it you should able to pull any faults in the system
jaimster is offline   Reply With Quote
