Old 06-11-2025, 02:07 PM   #1
Danimal
When you manually lock the car, do the instrument cluster and the interior lights turn off? If so, I have the same problem. However my car will generally lock after it sits for a day or so. After 30ish minutes of drive it’s back to not working. I replaced the passenger lock assembly, but no luck.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
