Old 05-20-2025, 10:32 AM   #1
LoneWolfGal
LoneWolfGal's Avatar
Assuming the engine isn't in yet, you'll never have easier access to those ancillary items. Would suck to put the engine in, then 2 mo from now the water pump goes out. It becomes a balancing act of how much you can budget for those extras, the odds of an old part failing, and the ease of being able to get to it if the engine is in the car. These projects rarely come in under budget, so the 'while you're in there's' always hurt the wallet but might be worth it if you have easy access to them with the engine out.
I had just replaced the front engine mount and my clutch had plenty of meat left on it, so I didn't replace those items. Was glad I replaced the injectors as those were much easier with the engine out and this was on my Cayman - would be more difficult on a Box. I didn't need to change the WP as it was new on my rebuilt engine. Bottom line, I didn't need to spend a lot of aux items, but swapping in a used engine into a more confined area of a Box brings more of them into the equation.
Good points, H.B. Besides the parts I've already replaced, including the IMS bearing, rear main seal, and cam chain tensioner pads (almost finished), I plan to replace a number of other items, including motor and transmission mounts and clutch disc, pressure plate, and throwout bearing, as well as various and sundry other things forum members have recommended.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
