Old 05-15-2025, 11:56 AM   #26
Jgkram
Danxx, sorry no one responded. The forum is not what it use to be. As far as the switches go, I have had mine in since the original post. No issues with anything as far as codes or operation is concerned. The only problem you might have is when the switches are turned on they stay on even if you shut the ignition off. It’s possible to drain your battery if you leave them on and forget them.
Jgkram is offline   Reply With Quote
