Old 01-15-2025, 11:45 AM   #5
djw8282
djw8282's Avatar
Use a multi meter to test the fuel pump wiring circuit for continuity and resistance.
that will tell you if the fuel pump is good or not.
Use a multi meter to test the the wiring to the fuel pump for power.
If your not getting power to the pump with key on then you have to find out why not.
If you don't know how to use multi meter to test wiring circuits... then go to youtube,
lots of info there on how to do it.
Hey, blue62. I finally got around to checking the fuel pump connections. I am not sure if I did it right, but I did a resistance test of the fuel pump connection points of ground and hot by connecting both probes to a single point at a time for a reading of 0.5 ohms for each. I did the same for the wiring to the pump (connector); testing the ground and hot wires for .0.5 ohms each. The battery was disconnected,
djw8282 is offline   Reply With Quote
