Old 01-13-2025, 11:58 AM   #2
mrian
Thanks Marc_986, that's very helpful. From what you're saying, I have a problem with both CAN-systems, which in my opinion would rule out the CAN-data wiring having a break somewhere being an issue.
That leaves me with the instrument cluster being faulty (seeming more likely now), or an issue with the CAN-power supply wiring, if such a thing exists.
I don't believe I clarified, I have no noticable issues with my instrument cluster. Whatever the problem is, I believe it is isolated to the CAN-computer.
By any chance, does someone know the pinout of the connectors on the instrument cluster, and which spots the CAN-related pins are? I think my next step should be to check for voltage at the power supply pins. If that check passes, replace the instrument cluster, and if not, repair the wiring.
mrian is online now   Reply With Quote
