Old 12-30-2024, 09:27 AM   #1
KevinH1990
KevinH1990's Avatar
I've done this on my 2000 and I expect that you can do the same on your 2004.
When you look at the center console, you will see that there are two trim panels on the sides. You need to pop those off. (If I recall correctly, you should grab the back of the panels and pull them out. Once the panels are off, the CD holder will slide out and you can install your shelf. If you can find a video or instructions showing how to install an aftermarket head unit, they should show exactly how to do it.
You are correct that there are two shelves available. One is installed in the upper position, and one is in the lower slot. The one in the lower slot tapers slightly to conform to the shape of the center console. I'll see if I can find the part number that I used.
You may want to check with someone who is parting out a 986 or 996 to see whether you can find a used part.
Good luck with your project.
