Old 12-19-2024, 12:35 PM   #1
Wret
I bought a less expensive regulator to fix the same problem. I spent all day trying to get the window to line up and finally gave up, took it out, put the old one back-with a zip tie. Its been working fine ever since, at least a couple of years.
You might want to troubleshoot why the zip tie fix did not work for you. Was it not tight enough? Did it not take up enough slack in the cable?
Wret is offline   Reply With Quote
