Old 12-16-2024, 05:55 AM   #18
blue62
Originally Posted by djw8282 View Post
Thanks for the reply blue62.
I have not. if you can detail the steps to troubleshoot in figuring out if the fuel pump is not getting power or a bad pump altogether I would appreciate it. I am pretty mechanically inclined but have not done any work pertaining to the fuel pump. Thanks!
Use a multi meter to test the fuel pump wiring circuit for continuity and resistance.
that will tell you if the fuel pump is good or not.
Use a multi meter to test the the wiring to the fuel pump for power.
If your not getting power to the pump with key on then you have to find out why not.
If you don't know how to use multi meter to test wiring circuits... then go to youtube,
lots of info there on how to do it.
