Old 11-25-2024, 05:57 AM   #1
blue62
Originally Posted by Hamstuh View Post
looked a good bit into it online, just wondering what you would recommend a starting point would be for a diag on this case. does this automatically mean the adjuster is bad and i'd need to swap said ~$800 part out or something to be cleaned and potentially fixed
The starting point is to determine if the adjuster functions or not.
It is an electrical devise so the electrical circuit portion can be tested with a volt meter.
It can be made to "test" actuate with the proper type of OBDII reader such as a Durametric or some of the Foxwell brand readers.
The second thing to consider is the high mileage ...there is very possibly high wear issues.
Access to things like the cams is very limited unless you pull the engine.
With these type of engine designs repairs can get costly.
