Old 11-24-2024, 03:50 AM   #1
Starter986
1998 Boxster Silver/Red
Are you getting spark at the plugs?
Is your fuel pump... pumping? With the car off... turning the key into the first position... do you hear the pump start (it's in front of you... at the bottom of the tank... listen closely.
Is your fuel filter clogged? Remove the rear line... crank... look for fuel.
That's where I'd be starting. Report back... we'll get it solved.
1998 Porsche Boxster
