Old 10-05-2024, 07:23 AM   #1
Pathologicaldriver
Thank you! That phone connector is really cool.
I’m still researching which lights to get, based on if I can use a center console switch, included basic toggle switch, or some bluetooth panel.
I’m also new to car wiring.
Did your lights come with a wiring kit? I have found that the kits that come with a switch and relay are the best way to go.
Otherwise, the simplest way is to run a wire from the 'phone option connector' under the center console for +12v to your switch, then on to the lights. See: http://986forum.com/forums/boxster-general-discussions/54064-what-does-plug-under-dash-go.html
Pathologicaldriver is offline   Reply With Quote
