Old 09-19-2024, 11:22 AM   #1
Danimal
I would go with the M030 especially if you already have the sway bars and springs.
My car came lowered on H&R springs with completely worn out dampers. I ended up going with bilstein pss9s because I needed new springs and new struts. But after going through all that trouble and corner balancing it, I don’t think it was worth it. The car is so well balanced that the adjustments to each corner were pretty minor. I doubt you’ll notice that 1/4 inch difference front to rear or side to side. But I have never tracked it, so who knows! At least I have corner balance bragging rights 😂
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
