Old 09-16-2024, 12:16 PM   #1
joshua3mm
If you already have 96k miles on clock you should not really think about IMS.
Just oil for metal particles to be on the safe side.
Foam in vents is a bigger job then you think if you want to make it all the right way.
Two more things to check, if there is any leaks under carpets specially under heavy rain.
Wysłane z mojego M2101K9G przy użyciu Tapatalka
joshua3mm is offline   Reply With Quote
