Thread: Oil Drip!
Old 09-10-2024, 10:58 AM   #4
elgyqc
elgyqc's Avatar
Originally Posted by evomind View Post
... Question.....
If the filler tube is leaking, will the car always leak or just when you put oil in it?
I would assume it will "leak" all the time that the engine is running, oily air will be exiting through the leak. You will also have a massive vacuum leak, which is not good. My Boxster S had this problem when I bought it, there was oil all over the rear of the engine and the chassis in the immediate area.
Grant
elgyqc is offline   Reply With Quote
