Old 09-09-2024, 04:59 AM   #1
Starter986
1998 Boxster Silver/Red
I've had that same code for 14 months. I suspect my code originated after I pulled aaway from the gas pump with the hose still in the filler tube. I've until June 2025 to have it corrected. Anhow...
A visual inspection, after having removed the passenger wheel and shroud revealed zero.
JFP (a highly respected member of this forum) recommended a smoke test. That is on the horizon.
What work did you do on the car before the code surfaced? I'd start there.
On another note... I expect to pay $100+ (emphasis on the plus) for the test. If a forum member woould like to recommend an inexpensive smoke machine... I'd aappreciate it.
OP... good luck with your fix.
1998 Porsche Boxster
