Old 09-08-2024, 06:09 AM   #2
tonythetarga
Clunky is generally one of two things, strut bearings or drop links. The drop links are easy to check. If the boots are cracked open, replace those. Cheap and easy. Strut bearings require strut removal and dissembling via the top nut. A bit more work.
I’d try tightening them first with a hammer gun.
Oh, could also be sway bar bushings. You could disconnect those and drive slowly and listen if noise goes away. Also cheap and easy to replace.
tonythetarga is offline   Reply With Quote
