Old 08-23-2024, 09:50 AM   #2
DesertDrive
Originally Posted by Hamstuh View Post
not sure if this will be the solution for you but it was for my first 99 boxster. After replacing quite a few starting components it ended up being the Crankshaft Position Sensor. My symptoms for starting were youd get complete power everywhere, it wouldnt crank but would give it one single push as if it wanted to. If by some miracle it did after lots of attempts, it would run 100% fine until it turned off and would basically do what it did to you. PartsGeek has em for a good price if you decide you wanna try it out
edit: if you did an engine swap, id 100% look inside and verify everything is connected properly. could also be possible a connector went bad since these cars are pretty old now and swaps are prone to potential damage if youre not 100% careful
The car came with an engine swap, the swap was done in 2013 so it has been running great for 10 years. I'll check the csps, thanks.
DesertDrive is offline   Reply With Quote
