Old 06-15-2024, 09:52 AM   #1
clueless1
Originally Posted by flmont View Post
( Maybe ) drain the oil,fill engine with a safe solvent or a 50/50 mix pull fuel pump fuse,..crank the engine over drain and repeat,..How much coolant did you add ..? Or if its just a little milky stay with the first suggestion, a couple more oil changes it may clear it up..I feel for you.. good luck Frank
I would not even use stronger additives like B12 additive in engine oil for fear of impacting seals.
…And I have to add, for emphasis, that $1000 for an oil change makes me want to change careers: How do I get in on that action? Is that Argentinian dollars? All things considered I vote your first step, and one that will continue to pay off long after this blip is just a distant memory, should be to high tail it outta there and find yourself a reliable Indy.
clueless1 is offline   Reply With Quote
