Old 05-29-2024, 09:40 AM   #11
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by elgyqc View Post
As Stiglitz sait it is a PITA. If I remember correctly it was the most difficult part of the installation. I was forced to get my girlfriend to help me. As I said in my thread...
"We started at the back on one side and worked our way around to the other side. The toughest part was the front and the secret was for one of us to push in the front of the foam to give some slack while the other rolled the the bead into place."
I think the important part is to compress the foam as much as possible by leaning on the cushion.
You can perhaps see in the photo that I inserted a wire staple at the very top to hold the bead in place (This was done with the seat out of the car and before the seat back insert was installed). If I was to do it over again I would put staples or screws in a couple of strategic places to hold the bead in place.
Thanks, Grant. I was crossing my fingers you wouldn't tell me it was just a matter of reefing on the leather to stretch it over the edge. Since that's the case, I've prevailed upon a couple friends of mine with big, strong hands to assist me in that endeavor. And perhaps applying some heat (again, judiciously) will help. I have a heavy-duty stapler I can press into service. However, I doubt the staples will penetrate the seat base's plastic. Seems to me, though, that Lseat is a little stingy with the leather. Wish they'd made the bottom edge on mine a bit longer.
Another question: Is the appearance and texture of the leather on your covers more like vinyl than leather? The grain of the leather on mine is absolutely uniform, with no variation whatsoever. Furthermore, the texture gives the leather a matte appearance; most leather seats I've seen are smoother. I was so suspicious I emailed Lseat and asked them if perhaps they had used vinyl by mistake, but they assured me it's leather, except for certain side sections, like the factory covers.
I'll tell you this, I'd much rather replace an IMS bearing than reupholster these seats. It would be easier by far. To achieve a decent result, I'd give it an eight or nine on the PITA scale.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
