Old 05-19-2024, 09:16 AM   #1
Rick_22
I did pull the climate control unit back out and checked all of the connections and they were all OK. I haven’t checked anything under the dash but it is unlikely since I haven’t done anything inside the car other than pulling the climate control unit out and putting it back in. When I run diagnostics on all of the other flaps and motors, they all check out fine. When I run the central flap diagnostics, I get no values at all. I’m not sure exactly where the central flap motor is located. I assume that it can be accessed under the dash?
Rick_22 is offline   Reply With Quote
