Old 04-09-2024, 01:49 PM   #33
elgyqc
elgyqc's Avatar
Back to my experience with the oil pressure gauges. As mentioned earlier, since replacing the blown engine in my 2000 S I had a cheap Amazon gauge and sender. At idle with the engine hot I was getting almost zero oil pressure on the gauge, but the oil pressure idiot light never even flickered... so I figured the pressure is low, but not critical (it is an "experienced" engine with around 130K miles on it). Today I completed the installation of the VDO gauge and Porsche (VDO) sender and suddenly I have 20 psi at hot idle! So it seems the Amazon kit that I have is not very accurate at low pressure. I am assuming that it is the sender that is inaccurate not the gauge, because I ran the VDO gauge with the Amazon sender and was getting the same low reading at hot idle.
Grant
