Thread: Startup noise?
Old 03-06-2024, 09:31 PM   #1
MasterDesigner
The issue is the bendix on the starter gets stuck and the engine drags it and throws it back with a squeeling sound, you need to remove the starter and clean it and lubricate the pinion gear and shaft, very common problem, I have the same issue but I have not get the time to fix it but will report back
MasterDesigner is offline   Reply With Quote
