Old 03-03-2024, 11:29 AM   #2
alexpinson5
You may not need to replace the actual IMS bearing, but you may want to contact LN and inquire about getting a replacement flange cover. Replacing just the cover requires prepping the car as though you were going to pull the bearing however (engine locked at TDC, cams locked, etc.).
Thanks, was hoping that was the case over a whole bearing replacement. Further searching shows they sell an o-ring and sealing bolt kit that is pretty inexpensive so I may not even need the flange. I'll reach out to them and see what they say.
alexpinson5 is offline   Reply With Quote
