Old 02-10-2024, 08:09 PM   #5
KevinH1990
KevinH1990's Avatar
Originally Posted by stateofidleness View Post
Awesome, thanks Kevin! Found a couple good writeups on the EEPROM reprogramming part. I have a programmer and software to do that (I hope - a perk of being a software developer lol).
Was hoping for a bit more of a plug and play swap, but I think this is manageable if all goes smoothly and I get my LCD screen fixed AND gauge fixed all in one go!
I had not programmed an EPROM prior to starting my gauge swap. I was fortunate that another board member graciously offered to guide me through the process. If you have prior experience with EPROMts, you are in much better shape than I was and you should be able to handle this.
I wrote a detailed document that contains everything I learned during my project. The file size exceeds the limit for attachments on this forum.. If you want a copy, please send me a PM with your email address and I will forward the document to you.
While you are planning the work, I recommend that you consider installing a 996 cluster if you can find an affordable used one, After using my car with the Carrera 5-gauge cluster, the 3-gauge cluster in the 986 looks like Porsche went overboard cutting costs on the 986.
