Old 01-13-2024, 12:54 PM   #1
Gigi
Gigi's Avatar
ball bearings vs cylindrical bearings
No problems, I did replaced the intermediary shaft double row bearing because the new one (EPS) is more durable than ball bearings, for the life time of engine.The double row bearing is sealed and you never know how worn out is on the inside. Keep an eye on any oil leaks around bearing flange when clutch work is performed and ask your mechanic to check for metal particles in oil filter when oil change is done. I’ve never been to a mechanic shop, I do all maintenance and repairs myself.
Gigi is offline   Reply With Quote
