Old 01-03-2024, 11:19 AM   #1
HorsiesInDaBack
Originally Posted by tcoradeschi View Post
Looks like 996 355 139 01 is the current fitment both front and rear (except for the 97 model year, which shows as 996 355 139 00).
Thinking it thru - are you sure the termination of the new hard line is in the correct location?
I am 99.9% certain the hardline terminates in the correct location. It clipped right into all of the retainers during the install. I could've cried it was so beautiful.
I started thinking and one was rubbing while on my quickjacks. Realizing that was full travel I found it did not rub while on the ground. The other (passenger side) I had hardly 1 cm of clearance on the ground. I adjusted the bracket nearest the caliper so that the angle on the bracket better mated to the angle on the wheel carrier. This gave plenty of clearance.
I saw that tarrett makes posts for the brake line bracket and might check them out. I want to change over to caliper studs as well.
HorsiesInDaBack is offline   Reply With Quote
