Old 12-13-2023, 05:29 PM   #1
obthomas
Codger/Starter
I have both the Durmetriic and and the Xtool I use the Durametric for Porsche problems and the Xtool for my other cars. It happens that the Xtool will change the Digital odometer on my 986 I think it has no problems with 986 clusters from about 1998 to 2004
Some time ago I replaced my 986 cluster for a 996 cluster. I used an eprom read write with my laptop to change the 996 cluster VIN and model year to match my 986. I had to also use it to change the 996 cluster gas tank calibration because it is different for 4 wheel drive vrs 2 wheel. The 996 gas tanks are different shapes.
What I remember pretty clearly is that the 986 boxster has an early cluster and a later cluster. They are not interchangeable. The later cluster has a blue and green and grey connector. I'm pretty sure that the later blue green grey clusters with the correct transmission are interchangeable. I do not know how to tell if a 986 cluster has an OBC until it is powered up. If it does you can activate it with the Duremetric.
2003 Boxster S, Chevy LS3.
obthomas is online now   Reply With Quote
