Old 12-13-2023, 09:04 AM   #5
Codger77
Codger
I believe you're incorrect. Can you support that claim? I'd like to be wrong...
From their marketing materials:
OE-Level Full Systems Diagnostic
XTOOL X100 PADS diagnostic scan tool can access the electronic control unit (ECU) of various vehicle control systems, including the engine, transmission, antilock braking system (ABS), airbag system (SRS), and read ECU information, read and clear DTC and check living data and freeze frames.
--Attention Please:
1. All the service function or key programming function can not work on ALL vehicles. Please come to us with your car VIN and required functions for compatibility check!
2. X100 PADS CAN NOT perform Mileage Correction function or Bi-directional control.
3. X100 PADS do not work for VW/for BENZ/for BMW specific vehicles or for Toyota smart key all key lost.
4. How to activate the x100 Pads Tablet: Please download the newest user manual from "Product guides and documents" (No activation code requiring anymore)
Many thanks to you and all for your replies. You are correct that the third connector is grey. My Boxter's VIN is WP0CB29872U661354 and cluster info is VDO 110.080.039/037 PORSCHE 986 641 233 00 EOD. I have found a couple of used clusters on line with very close numbers including one with close mileage that I am very interested in. Naturally, if a compatible cluster is plug & play that would be great since all I wanna do is drive & grin. I have some mechanical and VERY few digital skills with zero knowledge of the devices described here and would greatly appreciate further advice from you and other Members....
Codger77 is offline   Reply With Quote
