Old 11-20-2023, 06:55 AM   #1
iolinux333
The connector in the picture is the knock sensor. I don't think that you'll be able to re-use that connector. A couple people have posted threads about replacing that and I think someone did buy a new connector. I have a partial engine harness that I think still has at least one of those. If you have a U.S. address I can cut it with several inches of wire for you to splice back on and mail it.
***Note, There are two knock sensors, the other is on the other side of the engine and likely in the same condition.
Ah, thank you for that. Makes sense now. This is the knock sensor on the passenger side of the engine. The driver's side sensor is fine, I was able to get to it by removing some intake stuff. Mouse did eat the air conditioning compressor wire, but I was able to splice that. Mouse also peed over everything, so car smells like rodent pee. Anyway, I'll send you a PM.
iolinux333 is offline   Reply With Quote
