Old 11-18-2023, 09:19 AM   #6
986girldad
Originally Posted by ksjohn View Post
My shift shaft seal is leaking on my 5 speed transmission. Is this a simple seal replacement or is it the same nightmare as the 6 speed leak?
I found this part number, 012301457. Will replacing this fix the problem?
@ksjohn Did you replace this seal successfully? I'm having the same issue.
986girldad is offline   Reply With Quote
