Old 11-10-2023, 12:10 PM   #2
WillyT
Toppy986,
Thanks so much for the advice. I checked closer and found that the salvaged top has a three bow frame. I bought it. I have removed my six bolt and understand the microswitch on the B pillar must be removed to slide the frame back and ultimately lift it off of the car. I removed the metal compression clip and thought the switch would fall out but no luck. Don't want to break it. Any hints on how I can remove that micro switch? Photo attached. Thanks.
WillyT is offline   Reply With Quote
