Old 10-26-2023, 04:48 AM   #1
RobGrimsby
thanks
Originally Posted by tcoradeschi View Post
Welcome!
If you google about, there are lots of resources dedicated to Boxster top issues.
What I see is that your clamshell is likely slightly tweaked. You will want to check the stops under that rear edge to make sure that’s not what is causing the issue, and assuming it’s not, then you will likely need to tweak it back in the other direction so that it lays flat.
Does it sit the same way when the top is down?
I will have a look thanks for the reply. i did some google searches but i was not sure what to call that bit so not allot of results lol.
if it ever stops raining here i will drop the lid to see if it still sits the same
thanks
RobGrimsby is offline   Reply With Quote
