Old 10-25-2023, 10:40 AM   #1
DMoogle
Originally Posted by LoneWolfGal View Post
I slapped a set of Continental ExtremeContact DWS06 Pluses, an all-season tire, on my 986's 17-inch rims. They're significantly more surefooted than the Toyo set they replaced.
https://continentaltire.com/tires/extremecontact-dws06-plus
These look fine, but according to their website they're only available in 205/55 R17 (front), not 235/50 R17 (rear).
Should I mix brands for rear?
You can probably go a little wider as well, 215 / 245 if that helps in finding sizes. Check the overall diameter. The front and rear should be close to each other. It's not terribly critical if you have just ABS and not PSM
My car does have PSM. I think they're standard for 987.2.
I came across Yokohama's YT-GTX, which looks like a good fit, but unfortunately they're exclusive sold by Discount Tires, and the closest one to me is an hour away.
DMoogle is offline   Reply With Quote
