Old 09-29-2023, 12:31 AM   #3
particlewave
13.8 means that your regulator and alternator are working. I would check major connection points as you may be getting voltage, but low current. There's a large distribution block on top of the engine that is suspect. If the nut holding the cables is loose, this could be an issue. I would also check the cable nuts at the alternator and fusible link block.
