Old 09-28-2023, 03:03 PM   #2
clueless1
First make sure your fuses and related relays are good.
Then
Look up "testing Voltage drop on starter system" on youtube.
That will show you how to test the starting circuit for voltage drop issues.
Will do. When you say fuses and relays, I want to make sure I don’t miss anything: Fuses in drivers side panel (I think mainly C 1-4 and E1 but I will check everything).
Also relays in back trunk on driver side under panel? Is there any particular relay? (Or any easy swap for testing purposes?)
Any others panels or fuses to check? I’ve read here going through old messages about passenger side both in cabin (fuses?) and in trunk (relays) but it was hard to decipher?
Also, is there any easy way to check ignition switch?
clueless1 is offline   Reply With Quote
