Old 09-13-2023, 10:56 AM   #21
jarjar
Are the volts needed to operate the relay present at the panel the relay plugs into?
Did you try removing the fuel cap to release the pressure. ( put it back on )..then try to hear if the fuel pump operates when you turn the key?
jarjar is offline   Reply With Quote
