Old 09-13-2023, 09:14 AM   #1
adrianw
Double beep on locking saga.(Codes 01,44 & 47)
Cross posted from Pelican Forums.....
Hi,
The 2002 Boxster S I have (UK spec) double beeps when you lock it - so you have to press the button again to acutally lock it.
Occasionaly it all works OK for a wee while, but then starts to show signs again.
The central locking switch has the red light on too, pressing it gets a double beep even when driving.
The car has the codes 01, 44 and 47 against the I48 alarm system installed.
I see from various leaked work shop manuals that it is suggest for 01:
1. Disconnect plug connection X 11 (driver's side).
2. Check the line from X 11 pin A3 (pin side) to the alarm control unit
plug I, pin 5, for continuity.
3. Check the lines from X 11 pin A3 and pin 26 (sleeve side) for continuity.
and for 44:
2. Ohmmeter at pin 26 (sleeve side) and pin A3.
Display: < 5 Q
So my educated guess is that X 11 is the fat connector on the body of the car inside the door crease.
Anyone know if that is correct?
It looks to my un-trined eye that getting that connector off might be a 'door off' job?
Is it?
If I take the inner panel off the drivers door and wiggle the wires enetering the door lock mechanism I get all sorts of weird electrical things happening windows in open postion etc.
So I am left thinking I either have a harness integrity issue near the door lock mechansim or I have a door mechansim in poor health.
Anyony had 01, 44 and 47 before and managed to fix it without part swapping everything?
Cheers
Adrian
PS What is "sleeve side"?
adrianw is offline   Reply With Quote
