Old 09-12-2023, 12:24 PM   #20
Luckyman01
did look at the fuel pump relay
The relay tested good with a 9 volt battery.. The smallest pin is the one from the DME. It did test correctly in that it had 3.5 volts from the DME that dropped to zero when the ignition key was turned to the start position. The trouble shooting goes on.
Luckyman01 is offline   Reply With Quote
