Old 08-29-2023, 11:36 AM   #1
Sid - Aka - UK
Thumbs up
Team/All just following up having read all the posts. 5 days and locked out of the car - fob did not work, turning the key did not work/turning to lower the windows did not work.
Called out an auto lock smith.
Took 45 mins and first attempts pulling the door handles did not work. Second attempt - having again ballooned the window - taped the ignition key on the end of another rod and managed to turn on - to hard to get a purchase on the window buttons to press down and using a second rod to hit the central locking button on the****dash****- & opened****it.
Hope this helps.
On another note the engine light has been on for 4 years and 3 trips to garages - P numbers came up as co2 censure changed 600 mile latter comes on again - same P numbers this time change air mas censure - same again comes back on - at 1.800 revs stutters and learned to go gentle going up to 200 revs when driving! did a smoke test and no leaks could be found... Any help explaining/fix would be greatly appreciated.
Thanks in advance.
Sid - Aka - UK is offline   Reply With Quote
