Thread: Oil leaks
Old 08-28-2023, 12:29 PM   #23
blue62
Originally Posted by DShen View Post
Did you get a CEL for the filler tube leak? I'll experiment adding a little bit of oil through the tube and see if it leaks. How did you address your issue?
Thank you for explaining the tubes! So great to have a knowledgeable people on forums. The shifter cable was resting on top of the air con tube. Where you see the indention on the air con tube is where the shifter cable was touching. I just pryed it off and took the photo after.
There is no OBDII codes directly linked to the oil fill tube.
But if it had a big enough hole in it....that could trigger a vacuum leak code..
Something like the P1128 and P1130 codes.
