Old 08-25-2023, 09:00 AM   #17
elgyqc
elgyqc's Avatar
After pulling out the trunk liner I removed the spoiler motor mounting plate and was not too surprised to find the motor was missing.
I'm in the market for a replacement assembly.
More surprising was that I found some rust in the trunk...
... not major. I'll have to clean that up and coat it with rust inhibitor.
And I discovered that my trunk latch does not have the emergency cable that is normally hidden in the wheel well. There is the cable from the lever under the driver's door and an electrically operated cable that I assume should be operated from the key fob... that doesn't.
Grant
