Old 08-22-2023, 10:32 AM   #3
Gilles
Good advice, Blue. Thank you.
I purchased the least expensive compression/fuel pressure kit from HB months back. I did try to hook it up to the Schrader valve recently, but it didn't conain the proper fittings.. Thanks!
Regarding the Fuel Pressure Tester.. if you have an Autozone nearby, you can 'borrow' the fuel pressure tester' and when you return it you will get your deposit back.. 😁
Gilles is offline   Reply With Quote
