Old 08-21-2023, 03:00 PM   #15
blue62
If your fuel pump is not running with key on.....
Simply use a volt meter and check for voltage at the fuel pump wire harness connection with the key on.
If you have voltage at the connection then the pump is the issue.
If no voltage then you have a wiring, relay,or other issue with the circuit.
Simple.....
blue62 is offline   Reply With Quote
