Old 08-17-2023, 08:25 AM   #12
Jerry238
Fuses?
Check the related fuses and ground points for the airbag system.
Hi, Thanks for your response. I don't have a manual or wiring diagram, so I checked them all (I think). Those that were hot with key on were all good. I took my reader Icarsoft Porsche compatible back out this morning after watching some youtube videos. When I just read obd codes there are none. If I go into Diagnostics and manually choose AirBag system and then get codes it gives me a 0003 code and says below it power supply. Does that help to diagnose it. I live 3 hours from a dealer and 2 from a good indie shop. Do you know what the unconnected connector under seat is for? Brown and Brown/Red wire. John Keller says it is for Child deactivation of airbag for passenger seat and I believe he's correct. I don't have a manual or wiring diagram. All i did was move the seat forward to gain access to change water pump. What a headache. Maybe it's not a seat issue at all, but something electrical. Thanks, Jerry
Jerry238 is online now Report Post
Jerry238 is offline   Reply With Quote
