Old 08-12-2023, 07:32 PM   #1
Homeoboxter
I'd be spraying penetrating oil on those bolts then, when ready to start removing them... try to remove one. Resistance? Apply the flame. Me? I'm applying that oil liberally, and a few times.
Read long ago about removing a resistant nut/bolt. Recommendation was to try to, lightly, give the wrench some encourgement clockwise (tightening). Just enough encouragement to hear/feel the threads "give". I wouldn't give it but an eighth of a turn then backing off trying to emove the nut/bolt. Repeat.
Had an E30 that had the rattling. Was unmistakeable... a cat.
Good luck on the header removal!
Thanks! I'll try the tightening/loosening method with some WD40. One bolt is already broken into the head so I don't have high hopes about the others. It's gonna be fun to drill it out since I don't have a lift. If they won't budge I might as well pull the engine, I wanted to do some work on it anyways.
Homeoboxter is online now   Reply With Quote
