Old 07-27-2023, 02:32 PM   #1
Voynich
Oil Leak.... Not the AOS, doesn't seem like RMS or IMS.
I've got a 2003 2.7 Boxster with a odd oil leak. The leak is coming from the bottom of the sway bar on the right rear wheel. Swapped out the AOS hoping that would help, but no dice. Tried to track the leak up, but couldn't find much. Can the hose that runs from the oil fill in the trunk to the motor leak? (that hose is pretty oily) Seems far away from the IMS and the RMS (not centered on the transmission) to be that type of leak. If it is, I'll bite the bullet and pull the trans, but hope is eternal....
Thanks for any help!
Voynich is offline   Reply With Quote
